Speedo
Old Jan 26, 2009 | 07:30 PM
Real_Tech's Avatar
Default RE: Speedo
Does it do this with no other warning lights like the check engine light or ABS light on? The speedo gets its input from the ECM which in turn gets its input from the ABS module which gets the actual road speed from the wheel speed sensors. Most cases of speedo problems I've seenwere caused by wheel speed sensor problems but they almost always cause either the ABS or check engine light to come on or both.
Old Jan 27, 2009 | 01:12 AM
BuckMR2's Avatar
Default RE: Speedo
Mine had this shortly before a rear wheel speed sensor fell off....what happens is the sensor ring corrodes and can loosen before coming off.As it isnt fixed in place correctly it can lead to incorrect speedo readings.These speed rings are a common failure and Jaguar UK realised that problems started further north in Scotland and gradually appeared more down South (salt on roads?).
Saying that mine also had a new speedo under warranty before I bought the car but unsure why but I would guess its probably a speed sensor.
Old Jan 27, 2009 | 05:21 AM
racerx82's Avatar
Default RE: Speedo
I'm going to guess it maybe of an electrical issue of some sort if the wheel sensors are not your problem.
But, I do have one last instrument cluster for sale. PM if interested
RollaJones
Sep 27, 2015 03:31 PM
LnrB
Sep 25, 2015 08:58 AM
carcycle
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
