Sqeaky noise getting in and out of X-Type 2.5...
Old Nov 2, 2006 | 10:38 AM
smokinjag's Avatar
Default RE: Sqeaky noise getting in and out of X-Type 2.5...
I am facing the same issue, but it only happens to me when there are people in the back seat.
Old Nov 2, 2006 | 08:36 PM
racerx82's Avatar
I had the same problem with my 05....I checked and check and check...finally found it.....turns out it was the emergancy cable support bracket. It's held in place by a plastic clip that the brake cable rides through. The apprant lack of lubrication made it squeak....real annoying....
Check under both rear wheels, slightly to the right/left of the lower control arm. You will see this black (emergancy brake cable) running the length and a plastic clip it rides through. Grease it up in the plastic hole and hopefully that should fix it.....
________
Lovely Wendie99
Old Nov 3, 2006 | 12:09 AM
racerx82's Avatar
It's a booger to find, you actually need 2 people, one to push down on the rear (open the trunk, and have the guy push down on it) while the other one is under the car looking and listening.....if that does turn out to be the problem, i would look for another service station.....
________
Wendie 99
Joachim1167
Nov 7, 2020 09:18 PM
JimC64
31
May 30, 2016 03:04 PM
bydand
Sep 27, 2015 12:00 PM
ChrisJay
Sep 27, 2015 09:08 AM
UKnFor-dluv-expat
Sep 26, 2015 08:40 PM
