SRS code help
07 3.0 xtype, dash "airbag" light has been on for years.
I'm getting 4-5 flashing after starting before it goes solid. I see people post codes but none for 45.
I have a decent scanner and pull B2292 belt pretensioner, but it doesn't say what side.
Reading live data i get 26ohms driver and 2ohms passenger.
So question is what side is bad and is the pretensioner in the buckle end or the web/strap end?
Thanks!
Thanks!
While I did not have that issue before, the internet tells me:
It's the driver's side. Suspected fault is in the wiring - and part of that wiring is the clock spring.
The clock spring is the wire-band inside of the rotating steering wheel, which connects the electricidal features inside of the steering wheel (airbag, cruise control and other switches in the steering wheel) with the rest of the system.
I definitely have a problem with the seat belts. From different threads on this site I found
"had to take my passenger seat out . On refitting thought id finished but i have a warning B2292 which comes up with safety belt pre tensioner system"
and
"to check airbag, resistance should be about 2.2 ohm, same for seat belt"
I guess I could assume
b2292 isn't specific to either R or L side and that my D side tensioner is out out of spec
But I still don't know if it's the buckle end or strap end, both have what look like wired charges, and I'd like to be more confident before spending money.
and
b2292 isn't specific to either R or L side and that my D side tensioner is out out of specBut I still don't know if it's the buckle end or strap end, both have what look like wired charges, and I'd like to be more confident before spending money.
EsRay
Dec 26, 2024 07:09 AM
car5car
Mar 12, 2015 06:21 PM
eds123
Dec 30, 2011 02:40 PM
