stabilitaets-kontr gestoert jaguar error
Old Nov 5, 2015 | 07:38 AM
danuttzz's Avatar
Default stabilitaets-kontr gestoert jaguar error
Hello,
I didn't find this error so I opend an new thread.
So, this is the error I get when I start the engine, show me only 2-3 seconds and then disapere, this error I am getting also when I am driving and I think after 3000 rph he shows up again and the car is breaking for a few seconds.
On the tester the error is not showing, acttually on the tester the car has no error.
Could someone tell me what to do?
Thank you all and a good day
Old Nov 5, 2015 | 08:02 AM
Alfadude's Avatar
Welcome to the forums. I wish I could help you, but I can't seem to find an English translation to that phrase even when trying different text translations services, like Google Translate. If you could somehow find a way to give us the English translation of that phrase I'm sure someone could point you in teh right direction. Sounds like your car is going into limp mode. However, without more information it is hard to pinpoint.
Old Nov 5, 2015 | 08:51 AM
dwclapp's Avatar
Stability Control Disabled. Your X-Type going into limp mode and limiting the engine speed to 3,000 rpm.
Is the check engine light on? Can you have an auto parts store or mechanic connect it to an OBD code reader and tell us the error codes? There are many possible causes, so knowing the error codes is a big help.
Also, what year & engine size is your X-Type, petrol or diesel?
If you wish to change the display language, see this post: https://www.jaguarforums.com/forum/x...13/#post495297
Old Nov 5, 2015 | 09:20 AM
danuttzz's Avatar
Hello, thank you for the replay
The model is jaguar x type 2002 2.5 petrol automated gearbox
The problem is on a tester or OBD is not showing any error, so I don't know what to do.
On dashboard only lambda probe light is on
Old Nov 5, 2015 | 10:26 AM
b1mcp's Avatar
You will need to get the codes read by a more sophisticated device that can read body/chassis codes.
A cheap generic code reader will only show you engine related codes.
Old Nov 5, 2015 | 10:40 AM
dwclapp's Avatar
danuttzz: I'm not familiar with the lambda probe light. Do you see it in the attached diagram of an X-Type instrument cluster? If 'no', can you take a picture of your dash and show us the lambda probe light?
The lambda sensors are also call upstream oxygen sensors. There are two on our X-Types: one on the firewall bank, the other on the radiator bank. This post and the following one show the location of the upstream oxygen sensors and their electrical connectors: https://www.jaguarforums.com/forum/x...4/#post1084230
Have you checked for the 3 common vacuum leaks on our X-Types. Sometimes a vacuum leak can cause an oxygen / lambda sensor error. Take a look at this post: https://www.jaguarforums.com/forum/x...1/#post1309725
Attached Thumbnails stabilitaets-kontr gestoert jaguar error-jaguar-x-type-instrument-cluster.jpg
1960apache
Dec 3, 2015 09:54 PM
nesst2
Nov 2, 2015 08:00 AM
jagtoes
Nov 1, 2015 05:59 PM
jagtoes
Oct 31, 2015 12:22 PM
