Starter motor problems
Old Nov 29, 2012 | 05:29 AM
oee1268's Avatar
Default Starter motor problems
Hi all a newbie to the forum,
I am after a bit of advice , I recently had bother starting my 02 x type 2lt sport
And after looking through this site I had my starter motor out and bench tested
At a local garage that I trust
I replaced it this morning only to be met with the same problem , I have had a look at the starter fuse and its ok and have reprogrammed my keys ,
Dose any anyone have any info as to what might be the cause of my problem
Old Nov 29, 2012 | 05:35 AM
jimgoose's Avatar
What is the problem when starting, exactly?
Old Nov 29, 2012 | 05:39 AM
oee1268's Avatar
When you put the key in the ignition and turn all you get is a rapid clicking sound but no start ,all the light on the dash show when the key is in position 2 and that's about it
Old Nov 29, 2012 | 05:57 AM
jimgoose's Avatar
Could be a dying battery, or the starter's solenoid switch. Try with a known-good battery, and failing that see if you or someone can cross the solenoid switch manually, e.g. with a coin.
Old Nov 29, 2012 | 06:21 AM
oee1268's Avatar
Could I cross the solenoid in place with a long screw driver rather than remove to bench test again
Old Nov 29, 2012 | 06:23 AM
jimgoose's Avatar
You could. But whatever you do, make sure the car is in neutral with the handbrake on!
Old Nov 29, 2012 | 06:27 AM
oee1268's Avatar
Smile
Thanks for your help I will let you know the outcome and I might just remove it again better safe than sorry lol
Old Nov 30, 2012 | 04:04 AM
oee1268's Avatar
Seems it was the battery
toronadomike
Jan 22, 2026 10:13 PM
Jaguar Forums Editor
Jaguar Press release
Sep 4, 2015 09:18 AM
Bhoyceltic
US Southwest
Sep 3, 2015 09:11 AM
XJsc-guy
Sep 2, 2015 11:43 AM
TC Johnson
Sep 2, 2015 09:30 AM
