Starter Problem
Old Dec 21, 2017 | 11:31 AM
Oscar E. Banks III's Avatar
Default Starter Problem
How to replace the starter on a2003 X Type 3.0
Old Dec 21, 2017 | 04:08 PM
avern1's Avatar
Follow the link below to Jagrepair a site run by one of the forum members Gus. You can download the tech manual with all of the steps necessary for changing the starter.
JagRepair.com - Jaguar Repair Information Resource
Old Dec 29, 2017 | 09:38 PM
Thang Nguyen's Avatar
Except jack to support the engine, every thing work from the top; Disconnect battery cable, remove the engine brace bars, remove the starter battery cables, remove two bolts (or three? It have been for awhile), work around the hoses and wiring harness to pull the starter out, put the new one in and install every thing in reverse, take about an hour for the first timer.
Old Dec 29, 2017 | 10:57 PM
Dell Gailey's Avatar
The alternative method =
1. Deliver car to dealer for servicing appointment.
2. Assume the Jag owner stance (i.e. bent forward from the waist, hands grasping your ankles).
3. Remain in this position until car is completed and ready to be released to you.
4. Limp, waddle, crawl (because of the reaming you just received) to payment window.
5. Hand them all your cash, your first born, and sign the second mortgage papers.
6. Drive carefully home, listening for something else to go wrong.
Jagg
Aug 29, 2013 01:42 PM
Turbo_dash
Oct 9, 2012 06:28 PM
soonerpride316
Jun 8, 2010 03:48 PM
photog77
Jun 2, 2010 11:05 PM
GaryS
Oct 15, 2008 03:23 PM
