2000 S Type Starter Problem
Old May 27, 2010 | 04:17 PM
soonerpride316's Avatar
Default 2000 S Type Starter Problem
My 2000 S Type sounds like it is trying to start, it cranks but doesn't start. After a while it will "catch" and start right up. Does this sound like a bad starter?
Old May 27, 2010 | 04:29 PM
JagV8's Avatar
They hardly ever fail so it probably isn't faulty.
Old May 27, 2010 | 04:30 PM
What should I look at then? My car makes the starting sound but it wont click over so i can drive it. It is not the battery, I already checked that.
Old May 27, 2010 | 05:05 PM
JagV8's Avatar
Starting problems can be tough to figure out and may need a long list of tools etc as well as full details of the car and the symptoms. If you have an OBD tool, a 'scope, multimeter and can work through the circuit diagrams you may well be able to figure it out but if not then finding a competent tech may be the best plan. If you swap parts, it gets very expensive very quickly.
Things which could be the cause: CMP, CKP, MAF, MAP, air leak, coils, plugs, fuel pump, fuel filter, compression and many more but if it cranks for a while then it's not likely the starter.
Old May 27, 2010 | 06:58 PM
chucky60's Avatar
Default good luck
disregard
Old May 27, 2010 | 07:19 PM
chucky60's Avatar
disregard
Old May 27, 2010 | 07:57 PM
It seems to start fine when cold, when you drive it for a while it won't start. Let it cools off, it starts.
Old Jun 8, 2010 | 03:48 PM
Norgards's Avatar
Classic hot soak no start. If the car will CRANK and start when cold but will not CRANK and start after driving. You are 90% chance you need a starter motor. JagV8 is right the the denso starter has a good record. But after 10 years I hope you don't let that turn you in the wrong direction.
I answered your other port about removing the starter.
GOOD LUCK
stanjag
Dec 29, 2024 08:26 PM
MJ'S Jag
Nov 10, 2022 08:14 AM
martybmw
Aug 31, 2015 08:41 AM
nelsonht
Aug 30, 2015 06:01 AM
peterg19
Aug 28, 2015 08:42 AM
