Steering wheel swap
Old Sep 25, 2007 | 03:37 PM
Humy's Avatar
Default Steering wheel swap
Hey dudes,
I am looking to swap out my steering wheel on my 2003 X (use the same center portion, just change out the "wheel" part of it. Anyone do this? How hard is the job, is a matter of just looking for screws, unscrewing, and pulling around to figure it out?
Thanks in advance, cheers.
Old Sep 26, 2007 | 01:02 PM
bigdreams05's Avatar
Default RE: Steering wheel swap
If it's like any other car with airbags, I would disconnect the fuse for the air bags, then look for any holes in the steering wheel assembly or any clips that might hide any screws or bolts. Then remove the air bag portion to get to the wheel, and from the it's just one big bolt in the middle. Then, you'll need a steering wheel puller because that bitch is in there TIGHT!
Old Sep 26, 2007 | 01:15 PM
xdave's Avatar
With a 2003 wheel there are two small screws behing the stalks that hold the airbag in place. Disconnect the battery, leave it for ten minutes to let the backup batteries drain and then push the airbag in as if using the horn. That should expose the screws in the screw holes on either side and allow you to remove them. Then the airbag should lift right out. Be careful not to drop it, and always point it away from your face and body (hold it vertically, facing sidewards).
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
RobertTheBloke
Sep 24, 2015 11:48 AM
sogood
Sep 15, 2015 07:35 AM
Burdedw
Sep 12, 2015 10:39 AM
