Step by step door panel removal!
Old Feb 6, 2007 | 08:30 PM
andersen06's Avatar
Default RE: Step by step door panel removal!
Has anybody tried to take the rear door panels off?? I tried once and it didnt feel as smooth as the fronts so I stopped before I broke any clips!! Any Advice??
Old May 14, 2007 | 01:56 PM
IronCobra's Avatar
bump
Old May 14, 2007 | 03:01 PM
bigdreams05's Avatar
What are you bumping IC? If you're asking about the rear panel, it comes off exactly the same as the fronts!
Old May 14, 2007 | 10:48 PM
IronCobra's Avatar
Oh, I bumped it for the guy who had the door panel issue. Easier for him to find.
Old May 15, 2007 | 09:45 AM
aquill1's Avatar
Hey ironcobra you do it yet? I was curious also if you've ever heard of mdsound or previously mdx sound or konaki seeing as you said you had some years of experience in car audio...I enjoy doing car audio stuff but never done anything for a living...
Old May 15, 2007 | 11:04 AM
I had a couple of MTX subs before on my Nissan and they sounded beautiful and never blew on me despite the heavy pounding I gave them with my 1600 watt amp!
Old May 15, 2007 | 01:07 PM
aquill1's Avatar
Oh I was asking him because those are the car audio brands I can get!
Old Apr 28, 2009 | 07:04 PM
  #28
Jessy's Avatar
Where did u get new clips? where they the ones stuck onto the door not the pannel?
Old Feb 10, 2010 | 03:54 AM
  #30
Cadillac's Avatar
You should find them at those :
Nalley Jaguar, www.motorcarsltd.com
www.jagbits.com
Old Feb 10, 2010 | 01:50 PM
  #31
BuckMR2's Avatar
Another place you can mount the tweeters as you're a good installer is in the triangular section on the inside of the door mirror.
More here
https://www.jaguarforums.com/forum/s...ead.php?t=4556
Old Oct 24, 2012 | 06:04 PM
  #32
Boss_Fury's Avatar
Do the same steps apply for the rear doors?
My rear pas. side door sometimes locks up and wont even open.
~Boss.
Old Jan 15, 2015 | 10:36 AM
  #33
Djey11's Avatar
i m logged in but can't see the photos, i just have to retire the door panel because the door isn't posible to open by exterior, why can't i see the photos?
Old Jan 15, 2015 | 01:11 PM
  #34
clyons's Avatar
It appears that the photos haven been removed from their original location or the account that saved them has been deleted or deactivated in some way.
This youtube video may help
Old Jan 17, 2015 | 05:24 AM
  #35
hicat's Avatar
I can't get the images to display. This is what i see -->
Old Jan 19, 2016 | 03:43 AM
  #36
wigneys's Avatar
Hi,
Wondering if you can help me with:
"Step 2... Using a small and short flat head screw driver, remove the screw cover behind the arm rest and remove the screw."
I'm actually doing the reverse, as this screw is missing and I need to replace it to fix the door trim in place....I have obtained part C2S6858 but despite "looking" like the right part, it doesn't seem to seat properly (seems to big for the hole in the trim). I manually trimmed it down, but still no go. Is this the right part? Am I just being dim or clumsy? I am not the most mechanically gifted individual....
2007 X-type 400 - rear door (passenger)...
thanks!
Steve.
Old Jun 14, 2018 | 04:01 PM
  #37
new mexico's Avatar
Default Speakers
Originally Posted by IronCobra
Here are the steps! Beware, it is possible to damage a few of the door clips. They are $9.95ea for themale pieces (the part that attaches to the door panel)and $2.95ea for the female pieces (the part that attaches to the door). Most Jaguar dealers have several of them in stock. I snapped 2 of them while removing the panel. There are about 7 clips total. If you snap 1 or 2 than you can simply move some around and they will work just fine. I ordered new ones though.
Step 1... Remove the two screws from the bottom of the door panel.
Step 3... Use a medium size flat head screw driver and pry door panel away from the door carefully. (I wrapped the tip of the screw driver with a cloth to avoid scratching the metal).
Step 4...Usingyour hands, work your way around the doorpanel pullingit away from the door.
Step 5... Pull the panel away from the door about 3" and disconnect the door locking cable by lining it up with the hinge it is on and pulling up (you'll see when you look at it. very easy).
Step 6... Done! (total time about 5 minutes tops)
Where can I shop for front speaker replacements, mine sound terrible ?
Walter
Old Jun 14, 2018 | 04:11 PM
  #38
Dell Gailey's Avatar
A lot of members have posted good luck with this firm in replacing, upgrading, changing entire systems =
https://www.crutchfield.com/S-l0W3AT...-Speakers.html
Old Jun 15, 2018 | 02:35 PM
  #39
new mexico's Avatar
Default speakers
Thanks for the Info.
Walter
Old Dec 31, 2018 | 07:44 PM
  #40
CaliforniaGirl's Avatar
I don't want to remove my door panel. I just want to tighten the driver's side front door where the panel is loose - at the top left corner.
Any ideas would be appreciated.
