strut replacement
Old Jan 20, 2009 | 03:44 PM
teflondon's Avatar
Default strut replacement
I need to replace my front right strut.. I've replaced struts before on different cars but for some reason on my jag it seems to be quite difficult. I unbolted all the necessary screws and bolts and the darn thing still won't come out of the tower housing.
Any advise?
[IMG]local://upfiles/6168/008D7835F29343CCA4CA2E807D850CEB.jpg[/IMG]
Old Jan 20, 2009 | 06:14 PM
Real_Tech's Avatar
Default RE: strut replacement
The throw on the lower control arm of the X-Type wont allow the strut to come out of the knuckle or tower before bottoming out against the axle. It's a little more work but I always take the lower ball joint stud out of the knuckle and then CAREFULLY knock the knuckle off of the strut being very careful not to over extend the axle and pullthe boot and therefore the cv joint apart. For a first timer it may be easier to pull the axle nut and remove the outer splined cv joint out of the hub to avoid damage. This assumes you have a way to drive the splines from the hub without damageing the threads and end of the axle. They aren't usually overly seized in the hub but it will require either an air hammer or a good punch and heavy hand hammer to get the cv out of the hub. The first X-type strut I did I was cursing the designer for days. I couldn't beleive the extra work required to get the job done compared to every other strut I had done. Good luck.
Old Jan 20, 2009 | 08:29 PM
2xlooser's Avatar
Hey, I,ve got to do the struts and cv shafts on my X too. So any info you have would really help. I,ve done alot of front end work
before but not on a Jag. I like to know what I'm getting into.
Old Jan 21, 2009 | 08:46 AM
teflondon's Avatar
Thx for the response. I think I'm going to let my mechanic tackle this one. I don't won't to damage something else changing my strut. not worth it
Forcedair1
Sep 8, 2025 01:57 PM
RoyLittle0
May 25, 2023 02:38 AM
cissdm
May 3, 2016 06:02 AM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
