Strut and Shock Replacement Help
Old Apr 10, 2009 | 11:08 PM
jagnut1025's Avatar
Default Strut and Shock Replacement Help
Has anyone changed the fron struts and rewar shocks on an X-TYPE? Any suggestions? Can you recommend a particular brand - not too cushy - I like a firmer ride.
THANKS!
Old Apr 11, 2009 | 07:21 AM
Thermo's Avatar
Veteran: Navy
jagnut, just to state the obvious, when doing the front struts, make sure you have a spring compression tool handy. You will need that to take up the load of the front springs so you don't hurt yourself when you undo the nut on the top of the strut. TRUST ME!!!!!! I learned that one the hard way. Also make sure that after doing the struts that you get an alignment done.
As for brand, can't help you there. Dealing with my truck, most guys have been very happy with Bilstien shocks and I am sure that they will give you what you are after. I found them for our jags. They come in 2 flavors, comfort and heavy duty. I am assuming you are looking at the heavy duty. The heavy duty ones will run you $656 for a set of 4. Check out http://www.eshocks.com and look up part numbers VE3-5149-H0 (front) and BE5-6676-H0 (rear). I'm not saying that eshocks.com is the cheapest place or am I saying that I recommend them, but that is a shock brand that I would look at and it gives you an idea of the price that is being asked.
Old Apr 11, 2009 | 11:30 AM
jimmy's Avatar
ud
OEM sport package shocks are fairly firm, and not expensive... ask the dealer. or one of the techs here.
Forcedair1
Sep 8, 2025 01:57 PM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
KarimPA
Sep 3, 2015 07:32 PM
Busa R
Sep 3, 2015 05:01 PM
OkieTim
Sep 2, 2015 12:48 PM
