syn-go vs royal purple
Old May 10, 2010 | 01:33 PM
jn_lego's Avatar
Default syn-go vs royal purple
figured i'd post this
originally i flushed my transfer case out with royal purple a couple time, and i was never truelly happy with the outcome.
i bought sta-lube syn-go 75w140 fully synthetic from napa auto for 29.99 and flushed it last night
noises have ceased by 75%. greased the hell out of the center bearing for the prop shaft and it went down another 20%.
figured i'd share.
Old May 11, 2010 | 06:06 AM
steve11's Avatar
ud
When I service X-Types, which is less and less now, I use Syn-Go because it calls out the M2C192A spec. I considered both Redline and Royal Purple a few years back. I called them and the sales people all say their product is compatible, but they won't change their spec sheets to say so. In General, I am not that hot on either company as they are more boutique oil suppliers.
I am not a chemist or a petroleum engineer, so I'm not sure it makes that much difference, but I feel better using a product that will put the compatibility spec in writing. If your experiment is legitimate, then my cautions are borne out.
Old May 11, 2010 | 08:26 AM
jn_lego's Avatar
i orginally used royal purple a few times because i couldn't find redline and i didnt want to pay for the syn-go. 60 vs like 24 for what i needed to do.
i cant really explain what i felt. the car just wasn't quiet and didn't feel 'right'.
keep in mind i flushed with royal purple 3 times,
when i drained it sunday night (probably a month since last drain and fill) it was already blacked and had a burnt smell to it. whenever i drained it, i used the extra (over the 600 i was putting back in, 50 ml to account for loss fluid, probably should have kept more but whatever) but i put the extra in, and just let it run back out after a couple minutes. that even appeared off colored when it came back out.
but the car deffinently was noticably better. i'll do the rear after my next paycheck with the syn-go as well.
Old May 11, 2010 | 11:47 AM
steve11's Avatar
ud
$60 is really high for syn-go. Not sure where you're purchasing it from, but I pay $38 for a two qt. comtainer ($19/qt) at NAPA Parts.
The 2 qt. size is enough to do the rear diff and the transfer case.
Old May 11, 2010 | 12:07 PM
jn_lego's Avatar
i get it from napa auto in pa, 29.99 for 1 quart is what they charge though
inactualis
Oct 2, 2015 11:13 AM
millertic
Sep 30, 2015 08:11 PM
caldoofy
Sep 28, 2015 08:43 PM
dstary
Sep 19, 2015 09:47 AM
axr383
Sep 15, 2015 06:53 AM
