Synthetic Oil &$@$
Old May 13, 2009 | 12:58 PM
Striker27's Avatar
Default Synthetic Oil &$@$
I finally changed the oil in my car with Castrol synthetic 10w 30. My car has 15000 miles on it and did not leak one drop before the oil change!! Now after my oil change I get a drop here and there!!! I am just starting to hate synthetic oil!!!!
Sorry had to rant a bit!!! Off to clean thedriveway now!!!
Old May 13, 2009 | 02:38 PM
Cadillac's Avatar
Adversely I think you did a good change , I use 10 W 60 Castrol Syn as well. Make sure everything is just tighten as they are supposed to .
Old May 13, 2009 | 04:18 PM
MattSteele's Avatar
Where is it leaking from?
If it's from the oil filter or bolt, maybe they're just not tight enough. If it's leaking through the edges of the oil pan, well that's a different story. It probably says more about your oil pan gasket than the oil you used though.
Old May 13, 2009 | 08:43 PM
racerx82's Avatar
I can't imagine that syn oil will make your car leak. You sure you didn't spill any as you were pouring it and did you tighten your filter. Any why us 10-30, the book calls for 5w-30.
Besides, why us syn oil? change your oil every 7K miles and fill with regular 5w-30 oil.
Anyway, check to see where it's coming from.
MrWhite
19
Jun 14, 2022 07:49 PM
caldoofy
Sep 28, 2015 08:43 PM
42Ajd
Sep 26, 2015 07:04 PM
Woznaldo
Sep 26, 2015 11:02 AM
ahunt4
Sep 25, 2015 03:43 AM
