Thermo, I'v got a slow drip of power steering fluid,
Old Apr 10, 2009 | 09:38 AM
paul11117606's Avatar
Default Thermo, I'v got a slow drip of power steering fluid,
(red,orangy color) maybe one or two drips over night, in my 02-x sport, 79k miles. do you think its just the line or is it more commonly something else?.
Old Apr 10, 2009 | 04:00 PM
Thermo's Avatar
Veteran: Navy
paul, from my experience, normally a drip like this is from a connection of metal tubing to rubbing tubing. The best advice that I can give you is to first look up from where the drips are coming from. Follow the trail of fluid to the point that it stops Look at this point. If you have a connection near that point, then odds are, that is where your problems is. If the drips are coming from the power steering pump, then odds are you have a bad seal on the power steering pump. If it is a hose, simply replace the length of hose, refill the power steering reservoir and then start the engine. Move the steering wheel from lock to lock a few times. This will move the fluid through the system and remove all the air bubbles. Check the level and refill if necessary. Don't forget to check the connection to make sure that it isn't leaking still.
It may be worthwhile to have a greenie (scrubbing pad like you use for dishes) handy. When you remove the hose, clean up the metal connection to get rid of any rust/gunk. This will help ensure a good seal when you reassemble everything.
If it is the power steering pump, then replacement is about the only option. Again, fill the system, turn the wheel a few times and recheck level.
Old Apr 10, 2009 | 04:41 PM
Hi Thermo, yes that all makes sense. I thaught you would know about that, and it just so happens i do have a greenie, 'cause in my house i'm the one who has to do the dishes.
Dicque
Sep 19, 2015 12:53 PM
sogood
Sep 15, 2015 07:35 AM
1964Daimler
Sep 9, 2015 11:28 AM
MrMellor
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
