Throttle body possition sensor / pedal possition sensor
Old Apr 5, 2012 | 07:49 PM
Erndiego619's Avatar
Default Throttle body possition sensor / pedal possition sensor
Hello my name is Ernesto just had my car diagnosed with having a bad throttle body sensor by the dealer. After changing out throttle body assembly now gave me pedal possition sensor code changed out pedal possition sensor still in limp mode can any one help with what else might be wrong.
Old Apr 5, 2012 | 11:05 PM
Thermo's Avatar
Veteran: Navy
Erndiego, open up the hood of the car and locate the throttlebody. You will see 2 plugs on the throttle body. One plugs in on the motor side (this is the throttle position sensor) and then you will have one near the brake booster (this controls the motor that actually opens the throttlebody). If you look at the wiring to the motor, I bet you will find that it is damaged and normally the wires are starting to be pulled out of the plug. Otherwise, follow that wire bundle back looking for any damage to the bundle. Repair as appropriate.
xjrjag
Oct 24, 2024 03:09 PM
Gus
Oct 15, 2019 12:29 PM
ajacks86
Oct 12, 2017 08:51 PM
mrplow58
Sep 9, 2015 11:27 AM
