trans
Old Jul 18, 2011 | 08:04 PM
Jag Breeder's Avatar
Default trans
Anyone know how to check the level of the transmission
Old Jul 18, 2011 | 08:39 PM
Gold_04_X-Type's Avatar
Check the FAQ and do a search. Plenty of information including pictures are available.
Old Jul 19, 2011 | 11:32 AM
sidewalkman's Avatar
Short answer, motor running flat ground, remove the bolt on the side of the tranny, 1/2 way up, look in FAQ for pics, if the fluid is running out you're fine, if not the fill hole is under the battery with a rubber stop in it. If you asre going to fill it, drain it and refill it. There is someplace here a complete description with pictures on doing it with the motor running and flushing through the fluid, involves a long hose and funnel and 2 people.
n2audio
19
Jan 20, 2025 09:35 PM
Manjag
Oct 1, 2015 05:34 PM
mrplow58
Sep 30, 2015 08:56 AM
JTC3400
Sep 29, 2015 05:03 PM
