Trans failed
Old May 10, 2008 | 11:01 AM
Dennis's Avatar
ud
Default RE: Trans failed
Refresh my memory..What type/brand of ATF did you use initially?....Glad you're runnning again..
Old May 10, 2008 | 12:10 PM
Cadillac's Avatar
It's nice to hear that you had some problems but still say some good comments on JAGUAR which I verily appreciate
Old May 10, 2008 | 02:21 PM
jag_genius's Avatar
"basic frame work of the XF" ??
Old May 10, 2008 | 07:50 PM
canman's Avatar
Was the $5000 for just the transmission rebuild or did it include the transfercase also?
I have just taken my car to Jiffy Lube to have the Transmission and Transfercase levels checked. With the JTIS and posting from this and other boards we drained the transfercase (200ml of dirty oil) and filled using a hand pump and the "finger method" posted. Worked great and car is running much quieter and smoother now. PS my mileage is 32mpg highway 24mpg city.
Can someone tell me how to change the transmission oil. We found the Drain Plug and the Check Level Tube Plug but could not find the Charging Pipe Plug (JTIS diagram is not very clear). Is it the hex type plug behind the battery on top of the transmission (any pictures would be appreciated)? Also does one check the level with the engine running or do you turn off the engine after cycling the Jgate and then check to see if fluid comes out?
Old May 10, 2008 | 08:07 PM
Dennis's Avatar
ud
ORIGINAL: canman
The fill plug is a port just left and below the Battery box..it has a black rubber cork in it..I think it will be necessary to remove the battery and box to get at it...My method of fill would be to measure what drains out and put back in exactly the same amount and add maybe a couple of Ounce's to compensate for the years of evaporation..
Old May 11, 2008 | 01:07 PM
Dennis's Avatar
ud
ORIGINAL: willr
Originally I used the Valvoline High Milage fluid. From what I read and what Valvoline responded with (no one else responded to my questions, not even Jatco) the fluid met specs. But again, it was already failing.
Would that be the same as theMaxLife ATF?..Thanks
Old May 12, 2008 | 11:51 AM
ancientsanskrit's Avatar
...and the issue of proper trans fluid continues...
Glad to hear the car got fixed up, willr.
Out of curiousity, what kind of fluid did AAMCO use?
Old May 12, 2008 | 09:09 PM
Dennis's Avatar
ud
ORIGINAL: ancientsanskrit
LOL..No kidding eh?...As you see, I haven't made any moves yet..still gathering all the info I can find..
n2audio
19
Jan 20, 2025 09:35 PM
aode06
Jul 28, 2023 02:26 PM
Manjag
Oct 1, 2015 05:34 PM
mrplow58
Sep 30, 2015 08:56 AM
