transfer case
Old Nov 24, 2008 | 07:46 PM
Alaska Jag's Avatar
Default transfer case
I just rebuilt my tranfer case and got it back into the car. Its back on the road baby!
Anyway heres the deal, I had to make a tool to get a shroud/cover over top of the transfer case to get it out (took about 6 hours total to get the t-case out of the car).
After I had the t-case on the workbench, I determined that there was only about a 1/2 cup of burnt gearlube left in the case. The lack of lube caused one of the tapered roller bearings to fail (CR-0499 and race).
After a week on the computer there was only one place that I was able to locate this bearing, the other bearings (32204C bearing and race, HM88510 race (2 each), HM88542 bearing and HM88547 bearing) were all avalibe through local bearing shops. I contacted Patrick Seager at Seager Engineering and was able to get a complete set of bearings and a pinion seal.http://myworld.ebay.com/seager-engineering
I reassembled the T-case and installed it in the car w/Royal purple gearl lube. I have been driving it now for a week and have yet to have any noise, or problem.
The whole job cost me under $600.
Feel free to contact me with questions....
Old Nov 24, 2008 | 08:26 PM
Dennis's Avatar
ud
Default RE: transfer case
Good job on the work and research..too bad you couldn't have taken some pictures along the way..But thanks
Old Nov 24, 2008 | 08:56 PM
Size:  6.3 KBName:  AudiX6JYM-2.jpg
Size:  6.4 KBName:  T15ESSST101-1.jpg
Size:  9.9 KBName:  tshirt03-2.jpg
ORIGINAL: Alaska Jag
Hey Alaska Jag...............welcome to the forum.
Sounds like an awesome job you did on your transfer case.
Itd be great if you had done a write up on it with pics and info such as you have supplied. It sounds like it would have been a great addition to the FAQ section.
Jim
Old Nov 25, 2008 | 06:01 AM
racerx82's Avatar
Nice job!
Old Nov 25, 2008 | 07:13 PM
BuckMR2's Avatar
What is the capital of Kazakstan?
Only joking...great job
Old Nov 26, 2008 | 12:06 AM
Alaska Jag's Avatar
My bad bearing (closest to the output pinion) was the "CR-0499 and race", the cage was all but gone and the needles fell out as I took the case halves apart. The "CR-0499 and race" was the only bearing that Icould not find locally, even by dimensions.
I did not replace the crush sleeve, but was careful to tighten the nut as I was turning the shaft. The thrust washer was left in place when I replaced the pinion seal.
As far as I can tell, by talking to bearing maker (NTN North America) the CR-0499 and race were a limited run in Japan and was no longer a valid part number for North America.... I found the CR-0499 and race by Googling the bearing # and found Seager Eng. on the internet. He had a listing on E-bay UK for a Jaguar/Mondel transfer case bearing overhaul kit. The kit contained the bearings that I listed and the pinion seal. The shipping was a little pricy, but Mr. Seager sent it to me via the lowest price possible; therefore saving me well over $2,500 then having a shop do the job for me.
That is, if there was a Jaguar service center here in Alaska! LOL...
Old Nov 26, 2008 | 12:10 AM
Alaska Jag's Avatar
Default capital....
Astana
Old Nov 26, 2008 | 12:14 AM
Alaska Jag's Avatar
Default RE: transfer case photos
I'll try to get some photos that will help up this week...
Old Nov 26, 2008 | 03:14 AM
Default RE: capital....
Astana
Lol.........nice one Alaska
Jim
ArtyH
Oct 2, 2015 11:39 AM
millertic
Sep 30, 2015 08:11 PM
Johnken
Sep 30, 2015 02:46 PM
dmatthewman
Sep 30, 2015 10:10 AM
