transfer case oil change
Old Jun 27, 2011 | 08:19 PM
Thermo's Avatar
Veteran: Navy
disguay, the bigger thing I would be worried about is getting an oil that has the correct oil certifications. If you look in the jaguar manual, it will state the specifications for the gear lube. As I recall it is only something like "AGL" (don't quote me on this). I have used Mobil 1 full synthetic 75W-140 in my car. I go with that because it is easy to find. But, other have gone with Royal Purple and Redline. Both of those are also full synthetic 75W-140 lube. So, look around, see what you can find.
Old Jun 28, 2011 | 09:37 AM
disguay's Avatar
Thanks, just had to make sure that I had the right idea.
Old Jul 17, 2019 | 03:13 PM
Mike Swapp's Avatar
Can I get that pic of the valve you made?
Old Jul 17, 2019 | 03:23 PM
Dell Gailey's Avatar
Post #14, smfh
https://www.jaguarforums.com/forum/x...ge-help-47790/
https://www.jaguarforums.com/forum/x...change-124701/
Best option =
https://www.jaguarforums.com/forum/x...-point-105687/
Old Jul 17, 2019 | 04:05 PM
Thermo's Avatar
Veteran: Navy
Mike, is this what you are talking about?
The valve is a radiator drain valve with a collar on it to accept a tygon tube, then you have a 1/4 to 3/8 NPT reducer and then a 3/8 to 1/2" NPT reducer. You will have to shave the flats as the clearance is close. So, I would say to leave the flats on the 1/4 to 3/8 NPT adapter (like in the pic) and then you can use a thread sealant to lock all 3 parts together.
Old Jul 17, 2019 | 08:03 PM
dennis black's Avatar
i put in redline in my tranfer case when i bought it with 30,000 miles on it ,it now has 198,000 with no problems...its the original transfer case
Old Jul 17, 2019 | 10:51 PM
Did mine after I bought and drove it home to Utah from New Jersey. It was WAY ugly colored (@134,000 miles). See thread w/ pics here (used Royal Purple) =
https://www.jaguarforums.com/forum/x...change-181854/
bamforp
Aug 14, 2024 05:36 PM
Jpav27
US Northeast
Dec 17, 2021 05:40 AM
ZJag
26
Sep 5, 2016 03:33 PM
afterburner1
Dec 16, 2015 12:12 AM
pnwrs2000
Sep 3, 2015 11:55 AM
