Is Transfer Case 'REALLY' a widespread problem???
Old Mar 14, 2011 | 11:30 AM
j_bond's Avatar
Default Is Transfer Case 'REALLY' a widespread problem???
I think the forums tend to highlight the transfer case problem because people tend to join and post only when there is a 'problem.'
I would love to hear from anyone who has NOT had a transfer case grenade on them in this thread.
Maybe we should take a poll of those who have and those who have-not....
Old Mar 14, 2011 | 12:29 PM
sport30's Avatar
Banned
Any bearings and gears that run without lubrication are guaranteed to fail early.
this is much more than widespread, it is a certainty. A matter of when, not if.
There is no such thing as "sealed for long life" modern cars have "sealed for warranty period" only.
Old Mar 14, 2011 | 03:37 PM
Jerry the Jaguar's Avatar
102,000 miles and T-case has not exploded. Knock on wood
Old Mar 14, 2011 | 05:14 PM
Disco stu55's Avatar
2002 jaguar x type 2.5l
approaching 100000kilometers
transfer case in tact
Old Mar 14, 2011 | 06:04 PM
sidewalkman's Avatar
I drove off road in Jeeps for years, never had a T-Case explode, and I beat the heck out of all my vehicles off road. Never drove home without some sort of damamge. The only times I ever heard of it happening was during what is called drive line wind up. That happens when the front and back wheels are spinning at the same speed and the TC cant compensate and grenades. We've got traction control so that's not supposed to happen, but I can see if you've got too much HP and really sticky tires that the pressure in the TC might cause it to grenade, but we dont run anywhere near enough HP.
Old Mar 14, 2011 | 07:31 PM
Gergs's Avatar
All good here.
92k miles.
02 xtype sport 2.5
Old Mar 14, 2011 | 08:12 PM
j_bond's Avatar
Loving the feedback. Thanks guys. Keep it up....
Old Mar 14, 2011 | 08:43 PM
dennis black's Avatar
it just needs fluid and dont treat like a drag car
go to a suburu forum they all have problems if they dont take of it
my buddys wrx sti went after 29000 miles
awd cars just do the maintanace
if you buy used change the fluid the day you get it
bad
good
Old Mar 14, 2011 | 09:12 PM
Green Machine's Avatar
Cool No problems yet with TC
Bought ours in 2007 with 58,000 on the clock. Now has
72,000+ on our '03 2.5 auto = no problems with the TC yet. I'm going to check it as soon as weather warms a bit more, will probably change it and the rear differential. I'm thinking of changing out the transmission too. Although I really hate to touch things that are working great.
Only things that have failed so far, cooling fan controller and left headlight leveler. oh ya, also left front fog light. Replaced fan controller with a used unit and adjusted headlight to correct level not planning to mess with the mechanism also not worried about the fog light either.
Old Mar 14, 2011 | 09:33 PM
Jaggyx's Avatar
No problem with the TC here, knock on wood. I have 72k miles and I've changed it once at about 65k miles.
Old Mar 14, 2011 | 09:38 PM
j_bond's Avatar
I myself am at 46,000miles with nothing wrong on my 2006. Recently changed diff and transmission fluids as well as the transfer case at the *******.
Old Mar 15, 2011 | 08:30 AM
Gold_04_X-Type's Avatar
Amen to that!! If I had followed this simple rule it would have saved me a lot of TC work!
Old Mar 15, 2011 | 10:54 AM
Poglix's Avatar
04 2.5 SE auto. 68700mls. No problems no noise. Still on original fluid, due to be changed next month. I don't thrash it, and now only used once or twice a week. My local indie told me they have more trouble with TC's with viscous coupling fitted than ones without. Oil stays cleaner much longer. Mine has no VC.
Old Mar 15, 2011 | 12:19 PM
j_bond's Avatar
Good point about the VC
Old Mar 15, 2011 | 01:13 PM
queensnewbie's Avatar
2003 with 110K here, no TC issues at all and a daily driver. I put about 18K on it within the last year and nothing, although I rarely push the car. Had it since 77K, but previous owners and mechanics have noted no TC issues. I know it was at least moved when the shop replaced the oil pan gasket and seems to still be going strong. If the transfer case lasts another year without failure I'm satisfied.
Old Mar 15, 2011 | 04:25 PM
benebob's Avatar
ud
bad
good
Your buddies sti transfer case went huh? Might want to send him back for a refund since subbies don't have TCs. Guessing his front dif went which likely means the car was used quite hard. The sti is nearly bullet proof. Subbies and auto trannies don't agree if not cared for properly.
Now I once had a Nissan PU that went 30k and 4 years without an oil change and it still rotted away long before the engine gave out. I do agree that proper maint. and regular fluid changes are a wise idea for anything with a bearing, gear, valve or piston.
Old Mar 15, 2011 | 05:30 PM
JJCxtype's Avatar
2004 2.5 stick, 62,000 miles, changed tc fluid @ 55,000 and 58,000. No problems, hope it stays that way
Old Mar 15, 2011 | 07:20 PM
Trevor's Avatar
2003, 3.0. no problems 122,000 miles
Old Mar 15, 2011 | 08:00 PM
MeatBag's Avatar
No TC problems here either. I got my '03 daily driver 2 years ago with 35,100 miles on it, and I've added another 21,000 miles to that. I will be changing the TC fluid when she goes in for her 60,000 mile checkup sometime this spring.
Reading the posts so far it looks to me like everyone is saying "no problems here." Maybe we all just love to worry?
Old Mar 15, 2011 | 10:09 PM
seanshamrock0000's Avatar
I had to do mine at 100k
