Transmission problem
Old Jun 14, 2014 | 08:07 PM
carlvlsqz's Avatar
Default Transmission problem
Transmission will not go into gear.
Old Jun 15, 2014 | 08:09 AM
Thermo's Avatar
Veteran: Navy
Carl, the first thing I would check is to see what the fluid level is in the tranny. If the level is too low, the tranny pump can't build up sufficient pressure to move the gears. If that doesn't fix it, then your best bet will be to go to a shop to have them do a quick diagnosis on the car. I really doubt that the cable going to your tranny failed as you would be the first to have that happen.
RoyLittle0
May 25, 2023 02:38 AM
XJsc-guy
Sep 25, 2015 11:09 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
