Transmission problems maybe?
Old May 14, 2008 | 12:21 AM
Grim001's Avatar
Default Transmission problems maybe?
I was under my car the other day and noticed some black grease substance above the connection point between the transmission and the drive shaft, what could this be? Is the transmission fluid this color and texture? Or is there grese in the drive shaft? I have read about all the tranny problems and how there isn't much fluid in them so I thought I would ask. I plan on wipping it off and rechecking in a few days to see if I can tell where it is coming from. Any other ideas
I have an o2 Xtype 3.0
Old May 14, 2008 | 05:14 AM
FactoryJaguarTech's Avatar
Default RE: Transmission problems maybe?
The grease cap is leaking on the propshaft. I needs replaced.
Old May 14, 2008 | 05:18 PM
Grim001's Avatar
Thanks. Do you know if it is a dealer part? I'll be checking around.
Old May 15, 2008 | 10:02 PM
Grim001's Avatar
I went by the dealer and he gave me a gasket. Is this right? It is circular so it means I will need to disconnect the drive shaft to put it on, that sucks. Any good tips for doing this? Any recommended grease, they just said us CV joint grease.
RoyLittle0
May 25, 2023 02:38 AM
XJsc-guy
Sep 25, 2015 11:09 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
