Trip computer (can it be easily added)
Old Feb 21, 2014 | 09:22 AM
mbelanger's Avatar
Default Trip computer (can it be easily added)
It isn't high on the list of things I want to upgrade, but I was trying to determine whether the trip computer was a plug-n-play sort of thing or whether there is programming that needed to be done after the dash module was sourced.
The few threads I saw discussed a need to get the stalk with the TRIP button on it, but the '03 I bought already has that...but it is only capable of resetting the trip odometer given that the car lacks the trip computer buttons under the light switch selector.
If it would require reprogramming, then it isn't worth my time since, IMO, the trip computer functions were more of a novelty than anything else (at least based on how I have used it in the XK8)...but if it is just a matter of popping the dash plate to insert the new controls, hooking them up and starting the car, then it is something I would keep an eye out for.
thnx...
Old Feb 21, 2014 | 03:04 PM
Thermo's Avatar
Veteran: Navy
mbelanger, it will require reprogramming. You will also need a new headlight switch as the headlight switch has some buttons built into it that control the trip computer functions.
Old Feb 21, 2014 | 08:15 PM
mbelanger's Avatar
ok, thnx...didn't realize there was more to the stalk on the trip computer than just the 'trip' button at the end. That makes it more effort than it would have been worth, although even the need to reprogram would have been enough to move it waaaaaaay down the list of ebay or salvage shopping.
~~michelle
flyrr100
Sep 29, 2015 03:47 PM
Peeam
Sep 22, 2015 05:15 AM
Peeam
US Northeast
Sep 21, 2015 09:43 AM
Ipc838
Sep 13, 2015 03:27 PM
chatmanx
Sep 11, 2015 07:17 PM
