Trouble Codes
Old Sep 27, 2018 | 10:23 AM
Silver Panthera's Avatar
Default Trouble Codes
Hello,
I am having the following codes and am unsure at this point what my next course of action might be. Any help would be greatly appreciated. (2005 X-Type 3.0; 200,900 miles)
P0171 MIL
P0171 PEND
P0174 PEND
P1000 PEND
I recently changed all the plugs (gapped them to .052), all the coils, the upper intake gaskets, the fuel filter, the air filter, the cabin filter, the vacuum hose (that hooks to the back of the intake manifold). I plan on going back and checking all the connections for the hoses, but after that what would be recommended? Thanks in advance.Tim
Old Sep 27, 2018 | 10:56 AM
Alfadude's Avatar
Those codes are usually associated with a vacuum leak. The next logical places to check would be the IMT O-Rings and the brak booster check valve hose. Also double check the accordian hose from the MAF to the throttle body to make sure there are no leaks there.
Old Sep 27, 2018 | 11:27 AM
Thanks, Alfadude! I will check these as well.
Old Sep 27, 2018 | 11:55 AM
iownme's Avatar
i agree with alfadude
Old Oct 9, 2018 | 12:10 PM
Well I went through and checked all the hoses (all were good, no cracks or holes), I replaced the IMT O-rings, re-cleaned the MAF. After almost two weeks of driving, no codes and she ran like a champ.......... until today. She was struggling to start and the check engine light came on. It would turn over, but just wouldn't fire up right away. Once I got her started she would drive fine- no hesitation or lagging, etc, but the check engine light stayed on. So I checked the codes:
P0335 Crankshaft Position Sensor "A" MIL
P0335 Crankshaft Position Sensor "A" PEND
P1000
Any suggestions? Thanks in advance.
Old Oct 9, 2018 | 12:17 PM
Dell Gailey's Avatar
Lol, replace the CPS. There is a real good write up here of using a new allen head type bolt and repositioning the sensor in a new easier place.
Old Oct 9, 2018 | 12:28 PM
Post #45
https://www.jaguarforums.com/forum/x...w-62847/page3/
Sorry this is knock sensor replacement.
Old Oct 9, 2018 | 12:42 PM
Testing 2 or 3 wire crankshaft position sensor =
Old Oct 9, 2018 | 01:14 PM
Also, I had the battery and alternator tested and they were good.
Dell- the information on the camshaft sensor, the knock sensor and the crankshaft sensor is great. Thank you.
I am having a hard time finding the OEM part number for the crankshaft sensor. Is XR829578 correct?
What is the easiest way to change the sensor?
Could it be something else?
Old Oct 9, 2018 | 01:50 PM
That's why I posted the testing.
Symptoms =
https://www.1aauto.com/content/artic...ensor-symptoms
https://www.partsgeek.com/catalog/20...on_sensor.html
They go by left and right which is a bit confusing to X owners with the transverse engine. To us it's front and rear. Both sensors are the same. Replacement is pretty straightforward, remove bolt, disconnect harness, remove/replace, reverse disassembly. Had one guy just a couple of weeks ago that switched them to see if the problem (different) he was having followed the switch (it didn't).
OEM Part Number(s): XR853846
Old Oct 9, 2018 | 04:02 PM
https://www.jaguarforums.com/forum/x...-sensor-87516/
OE-XR829578
Old Oct 9, 2018 | 09:18 PM
iownme's Avatar
dell...he needs a crankshaft sensor... that guy who swapped em over swapped camshaft sensors, theres only 1 crankshaft sensor which from what i remember is quite accessible, even more so with the lower wheel arch cover and wheel removed (U.S passenger side)
Old Oct 9, 2018 | 11:05 PM
Yeah, I get my cranks confused, lol.
Old Oct 10, 2018 | 06:20 AM
iownme's Avatar
and i woke up cranky today
Old Oct 10, 2018 | 07:42 AM
Dell- again thanks for all the input on this.
iownme- I woke up cranky also......must be an x-type thing
If the car is jacked up, is it necessary to remove the wheel and the lower arch cover? Or can it be done without removing them? I have not crawled under there yet to look.
Old Oct 10, 2018 | 10:52 AM
iownme's Avatar
i just went and looked and i think at the very least the wheel has to come off....there is an opening in the wheel arch which may or may not allow you to get a wrench in there, either way, the cover comes off in about 30 seconds.
i dont think you can do it from under the car, though it may be possible to snake a thin arm up there and do it by feel
Old Oct 10, 2018 | 12:30 PM
Kinda boring video and showing a 2 wire sensor (see above for the 3 wire ground/power) testing for wiring, signal and sensor failure. If wiring tests out, then it is the sensor. He spends time on the 340 (camshaft sensor) code but also shows how to test for the 335 crankshaft sensor code (again if wiring tests good it's the sensor).
jaguar0206
Dec 8, 2019 07:43 PM
SynySTR
Oct 17, 2014 09:33 AM
bassman64
Apr 20, 2014 04:25 PM
XTypeJagMan
Feb 28, 2014 08:38 AM
brisbon
May 20, 2011 10:05 AM
