Trunk won't open
Good morning from Texas. First, I think I may have incorrectly tried to post this the other day. I am having issues opening my trunk. It's not working with the FOB, but if I unlock the car, I can hear something in the locking mechanism and can press the button, and it will unlock. It won't pop up, but I can lift it. Then there are time pressing the button on the trunk will do nothing. I have read treads where people are talking about popping out the tail light to pull the emergency release, and some other quick options for accessing the truck. What do I need to replace to fix the issue. I have a 2003 X Type with a 2.5. Any advice would be greatly appreciated. Thanks, Mickey
You could do this first so you don't get caught out before the fault becomes permanent!!
https://www.jaguarforums.com/forum/x...ight=emergency
If it does become permanent before you have an emergency access arrangement, this post gives some better/cheaper answers than breaking a rear light.
http://www.jaguarforum.com/showthrea...highlight=boot
As your problem is intermittent it looks likely that the cause is a fractured wire in the flexible tube between the trunk lid and the body that has broken. A repair by soldering in a joining wire is straightforward. It's not an uncommon fault.
tnt
May 23, 2022 07:30 PM
rsd911
Apr 9, 2015 02:41 PM
MrJagXJ
Sep 15, 2013 06:32 PM
Mccalist
Dec 14, 2009 09:05 AM
