Turn Signals Relay and Oil Dipstick
Old Oct 1, 2013 | 08:15 PM
cjebodh's Avatar
Default Turn Signals Relay and Oil Dipstick
Hey Guys
Where will i finf the turn signal relay fuse for a 2003 x type jaguar, also where is the oil dip stick located in the engine, I've found the transmission stick red handle but can seem the find the oil dipstick
Old Oct 1, 2013 | 09:51 PM
Thermo's Avatar
Veteran: Navy
cje, there is no tranny dip stick in the car. The red handle that you found right in the front of the engine (to the left side) is for the motor oil. The only way you know that you have the proper fluid level in the tranny is to go through a procedure and remove a fill plug which should have the fluid level just below the edge of the plug.
As for the turn signal relay, there isn't one in the car. The relay action is controlled by the GEM module. What are you trying to figure out, may be I can help you get to a resolution.
Old Oct 2, 2013 | 03:16 AM
Carl,
I've moved this thread from General Tech Help to X-Type forum.
We like to keep model specific questions in the appropriate tech forum.
kelliott
May 31, 2022 05:26 PM
mbergen
Oct 23, 2019 10:26 PM
jaguarbill
Sep 5, 2015 11:43 AM
AL NZ
Sep 4, 2015 08:39 PM
laserguy
Sep 3, 2015 02:02 PM
