two niggling problems with my x type
Old Jan 4, 2012 | 11:11 AM
Richard_G's Avatar
Default two niggling problems with my x type
THe first prob is when i drive my car for mre than a min my outside temp guage reads mad, usuall round 30 to 40 degrees but when u first get into it after its been sitting the reading is correct.Any ideans?
The second is when i turn the ignition on the info readout says quite often that the dsc has system fault? any ideas on these. i have noticed the airbag light satying on a few times if thats related ?
Old Jan 4, 2012 | 03:21 PM
Thermo's Avatar
Veteran: Navy
Richard, I would first look at the positioning of your temp gauge sensor. It is located behind the grille. It is very possible that it has gotten banged and what is happening is that part of the bracket is in touch with the radiator, which is causing it to absorb some of the heat that the radiator is trying to remove, leading to the artificially high temp. If it is reading low, then you probably have a wiring issue and you need to do an inspection of the wiring to see if you have any cuts in the insulation.
As for your DSC fault, a lot of times it is a rear wheel speed sensor issue. TO isolate it to a specific wheel, you will need to take it to a shop or find an auto parts store that has a fancier code reader that will also read the ABS faults (these are the C---- faults where ---- is 4 numbers). Odds are, you are looking at a failed ring to the speed sensor which will require a new CV axle for your car.
stanjag
Dec 29, 2024 08:26 PM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
johanasu
Sep 3, 2015 12:39 PM
martybmw
Aug 31, 2015 08:41 AM
nelsonht
Aug 30, 2015 06:01 AM
