Under bonnet sound deadening panel sagging.
Old Jul 5, 2021 | 11:45 PM
domain58's Avatar
Default Under bonnet sound deadening panel sagging.
Hi All,
The sound deadening panel on my 3l petrol engine is sagging and rubbing on the inlet manifold. Has any member fixed this problem and if so how. Replies appreciated.
Thanks to the members who responded to my post re foot rest.
David Bruce.
Old Jul 6, 2021 | 02:26 AM
Dell Gailey's Avatar
  1. 1 = C2S44059
  2. 22 = C2Z3567
https://www.hoodliners.net/product/2...rue&cst=custom
https://www.jaguarforums.com/forum/x...cement-171495/
Old Jul 7, 2021 | 01:48 AM
domain58's Avatar
Hi Dell,
Thanks for the quick reply. My under bonnet panel is in too good condition to warrant a replacement. I was wondering if any members had fitted a curved metal bar that would use the original two mounting screws and because of the bow would hold the panel off the inlet manifold? The same thing happened to my 03 X type we bought new.
Regards, David Bruce.
Old Jul 18, 2021 | 02:18 AM
domain58's Avatar
Default under bonnet sound panel sagging.
Hi members,
I have fitted a piece of flat steel about 20 mm wide put it through a set of rollers to give it a curve drilled a hole at each end and using the original mounting screws screwed it in to place.
David Bruce.
davidladewig
Jan 14, 2020 12:30 PM
kage7
Sep 7, 2018 08:19 AM
Cruzer56
E type ( XK-E )
May 18, 2016 06:30 PM
GordoCatCar
Feb 4, 2010 09:22 AM
