Urgent part identification
Old Feb 17, 2012 | 06:39 AM
jonesy1974xtype's Avatar
Exclamation Urgent part identification
Hiya
I've a 2006 2.2 diesel x type.
For reasons known only by god, I shut my bonnet yesterday with the battery cover still off!
The bonnet didn't quite shut and the battery cover cracked the part below which is connected to the water reservoir via a pipe. Water now drains from the crack emptying my water reservoir.
Please see the pictures below and help me identify the part.
Thanks,
Jonesy
Attached Thumbnails Urgent part identification-imag0236.jpg   Urgent part identification-imag0237.jpg   Urgent part identification-imag0238.jpg   Urgent part identification-serial-number-23708594.jpg
Old Feb 17, 2012 | 07:28 AM
It's the thermostat housing isn't it?
Take a look here
File Type: pdf
Old Feb 17, 2012 | 02:53 PM
Thermo's Avatar
Veteran: Navy
jonesy, that appears to be a thermostat housing to me. I am not infinitely familiar with the diesel variants, but based on the hoses running to and from the part, that appears to be what it is. Should be a fairly cheap fix as the thermostats are not that expensive.
Old Feb 17, 2012 | 03:28 PM
Languid's Avatar
Likewise, I'm not familiar with the diesel at all, but it certainly is the thermostat housing. Before you rush to the Jaguar Dealer, see if you can get an aluminium aftermarket replacement such as is available for the petrol engined cars. They are a vast improvement.
Cheers,
Languid
Old Feb 21, 2012 | 06:58 PM
Thanks guys. Got the hose for £17 new and thermostat for £40. Plus new coolant. Easy fix - removed 3 clips and one bolt. Lesson learned. Had already bought the plastic thermostat so didn't get the aluminium one.
If anyone else in the uk is reading this I recommend Quickco in Trafford park Manchester for new bits. They mainly do ford, but also do genuine jaguar parts. worth getting a quote.
Scott B
Oct 24, 2015 01:29 PM
wardo5757
Sep 11, 2015 11:31 AM
jaggermang
Sep 8, 2015 07:07 PM
DAN L
Sep 8, 2015 07:21 AM
1100me
Sep 7, 2015 06:26 AM
