Used AC compressor
Old Sep 15, 2024 | 01:23 PM
Xander2004's Avatar
Question Used AC compressor
My X type's AC compressor is leaking, is it a idea to install a used one since brand new ones cost 400-700$ with install depending where you get them from.
Old Oct 1, 2024 | 09:35 PM
Ronks2's Avatar
with a used you might be inheriting someone else's problem. The price you threw out seems a little high, was it for new or rebuilt?
IF you go used, look into the update. our compressors were a variable run for lack of better terms at 10:30 at night. basically you pull one of the valves out and flip it around. i did that on mine and replaced the few o-rings where the hoses connect to the compressor, and even though i did have a leak around the shaft, it hasn.t been an issue needing a refill in the year since i did it.
Good luck either way
Old Oct 2, 2024 | 09:27 AM
DaveAllen's Avatar
Did the installation of the new compressor include a new drier? I think this is usually required for the compressor warranty?
FWIW - if a significant part of the cost is labor, I usually go for the best parts to avoid a re-do. Used or new? Depends on budget and how long you want to keep the car.
Good luck. HTH, Dave
richg
Aug 7, 2022 12:15 PM
sanchez
Aug 7, 2018 11:46 AM
bmcinsd
Sep 1, 2017 02:27 PM
askotnicki
Jul 16, 2017 01:17 PM
jahlack
XJ40 ( XJ81 )
Jul 30, 2013 02:56 PM
