Vacuum leak?
Old Nov 6, 2011 | 11:19 PM
seanshamrock0000's Avatar
Default Vacuum leak?
Had a vacuum leak last year. The car would sputter when I started it and do the same for a few minutes at red lights ect when i wasnt giving it gas until it warmed up, and i had the "cruise not available" warning. I had it fixed. Now that its getting cold, every time i start it, it does the sputtering, feeling like its gonna stall thing until i give it gas once and then its good. Early stages of a vacuum leak?
Old Nov 7, 2011 | 05:01 PM
Thermo's Avatar
Veteran: Navy
Sean, check the big 3 hoses (PCV valve hose, brake booster hose, and the IMT valves). odds are, from what you are describing, you have a split PCV valve hose. But, I am taking a guess here.
Old Nov 7, 2011 | 09:03 PM
mohrd's Avatar
Seems the vacuum leak season was just over and here it is starting again. Next, prop shafts will be whining...and then it will be Christmas. Time flies.
Both of these issues are aggravated as the weather gets colder.
Old Nov 8, 2011 | 02:44 PM
just last winter i replaced the pcv hose and all the imt valves.
Old Nov 8, 2011 | 11:26 PM
mohrd's Avatar
Any CEL? Did you get the codes read?
Old Nov 9, 2011 | 12:55 AM
Stiffler4774's Avatar
Had this same problem about 4 years ago. It would sputter when it was cold outside. But was okay when I gave it gas or until the car warmed up. Took it to the dealer and they replaced the intake upper and lower seals. I also had them put in new spark plugs. Everything worked well after that.
clubairth1
30
Sep 3, 2025 04:38 PM
silkcat
Jan 18, 2025 04:29 AM
Bcrary3
Feb 21, 2023 04:29 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
