vacuum reading at idle
Old Nov 30, 2011 | 03:41 PM
gbrutschea's Avatar
Default vacuum reading at idle
does anyone know what the vacuum should be for a 2.5 at idle. I have a misfire code nightmare and the sensor is around 8 inches of vacuum. This seems awfully low. I cant find the specs anywhere.
Old Nov 30, 2011 | 04:36 PM
Thermo's Avatar
Veteran: Navy
gbrutschea, normally the vacuum at idle is around 20+" of vacuum. So, it sounds like to me you have a vacuum leak somewhere. I would check the big 3 hoses and then see what you have at that point.
Old Dec 1, 2011 | 07:00 AM
gbrutschea's Avatar
Default cold idle stumble
I got in this morning idle stumbling no brake assist. I am going to dealer to get new vacuum line for brakes. Goes away when car warms up. Multiple misfire engine codes p00300, p00302, p00303, p00304, p00305, p00306, p1316, p1111. It really showed up in the cold weather this morning. I was pulling my hair out because I had not seen this only the cel before. I had replaced the pcv tube and I will double check this first. I hope I dont have a cracked fitting. Someone had borrowed the car and I thought they over revved it in neutral.
Old Dec 1, 2011 | 04:01 PM
Thermo's Avatar
Veteran: Navy
Check the brake booster check valve line. If you are going to have an issue, that will be it since you have already done the PCV line.
Old Dec 1, 2011 | 07:37 PM
gbrutschea's Avatar
I could not find anything wrong with the brake booster/check valve line. I went ahead and changed out the yellow o-rings for the green coated ones. I will see in the cold morning if it is fixed.
Old Dec 2, 2011 | 05:19 AM
gbrutschea's Avatar
Well idle problem is fixed but it got below freezing and it seemed the brake pedal went to the floor at the end of the block. I will put a scan tool and check the vacuum reading tomorrow.
Old Dec 9, 2011 | 08:12 AM
gbrutschea's Avatar
changed out o-rings. seemed fine. went below freezing last night. blinking cel and brake light came on
clubairth1
30
Sep 3, 2025 04:38 PM
Bcrary3
Feb 21, 2023 04:29 AM
explorer364
Sep 14, 2015 07:43 PM
explorer364
Sep 11, 2015 05:44 PM
OkieTim
Sep 8, 2015 04:48 PM
