valet key transponder
Old Jan 25, 2017 | 03:00 PM
claytoncramer's Avatar
Default valet key transponder
Lost one of my 2005 X-type fobs. Ordered and programmed new fob. The key itself is not copyable by any locksmith I can find, and my dealer says they can't copy a key--just order a replacement key and fob for $400.
I have a valet key. I understands the valet key also has a transponder, and it does work without the fob to start the car. Can I just use the valet key unless I want to get trunk access? Does anyone know of a locksmith that can copy these Tibbe keys, perhaps mail order? I have a blank key that came with the fob.
Old Jan 25, 2017 | 05:01 PM
jagger's Avatar
The Tibbe keys are not too hard to cut by hand. If you have some mechanical ability and a jewelers file you can cut the key. I have done it. There are just 4 angles to be cut at each of the 6 positions. You only need to actually cut 3 angles as the 4th angle is not cut. Do this on each of the 4 sides of the key.
This web site has some good pictures of an 8 position key.
How To Decode Your Jaguar Tibbe Key And Find Your Tibbe Key Code - Car Locks and Keys
There are 8 position Tibbe keys but the Jag X-Type uses a 6 position key.
Pete.
Old Jan 27, 2017 | 04:39 PM
Cash Jackson's Avatar
Pete.
GoodDay!! can this be used to remapp your immob!! key
Never To Kool For Skool!!
