VLED's 194 5w light flickering problem
Hello all, I had installed a set of LED city lights (194's) from V-LEDS.com and I have a problem with the left side light. It always illuminates correctly when first turned on, but I notice after having my hi-beams on occasionallywhile driving around when I park in the garage I see that the left side LED is flickering erratically. It will be off, then flicker, repeat!
Makes me think somehow I have the famed Lucas "on, off, and flicker" switch installed
I have taken the LED out and made sure the two contacts are not misaligned and I made sure the connector terminals were not spread apart to far. I was wondering if this was a case of excess heat problems or do I just have a bad LED??
[sm=helpout.gif]
Thank you!
[sm=helpout.gif]
Thank you!
I heard back from V-LEDS.com and they are sending out a new set of LED's at no charge. They said normally they have a 30-day warranty from purchase but were still willing to replace them.
I had ordered them in February but did not install till mid-late March.
I wanted share the stand-up customer service from V-LEDS.com to all of you.
I will post back with the results of the new LED's.
can anyone shoe the exact bulbs they used for there side markers lic plate and dtrl...i know its a 194..2825 but there are too many type on vleds.any help would be great... be ready for the spring unveil of the X !!!!!!!
QuintonChester
Jun 26, 2016 04:31 PM
