weird break issue
Old Jan 11, 2009 | 06:20 PM
jvegas's Avatar
Default weird break issue
I have a weird issue with my breaks. When I am going in reverse and apply the break they make a hoooon sound. I have only heard this once or twice before after I cleaned the wheels with wheel cleaner. It would then go away after I drove for a few miles. Now, it makes the noise any time I drive in reverse and I have not cleaned the wheels in months (because of the winter). I just had the rear tires replaced and they said the breaks look ok... what should I look at or do?
Old Jan 11, 2009 | 08:28 PM
Oldengineer's Avatar
Default RE: weird break issue
Vegas:
My 06 did this. There's a Jag Technical Service Bulletin out on it. There's some bushings in the rear suspension that have to be replaced to make the noise go away.
Regards:
Oldengineer
Old Jan 11, 2009 | 09:07 PM
jvegas's Avatar
and yours only made the noise when you applied the breaks?
Old Jan 12, 2009 | 07:13 AM
The Chris X's Avatar
If you have some time on your hands and a nice dry garage, pull the rear wheels and pull the rear calipers and clean everything with BRAKE cleaner. Lube up theback of the pads, caliper sliders, and all metal contact points with the appropriate grease. Just sounds like they are dirty to me or you might have some glazing of the rotors/pads.
Is the noise coming from the rear of the car or the front or all 4?
Old Jan 12, 2009 | 09:51 PM
I did all that, and, even replaced the rear shoes. It still made a very loud moaning noise when I hit the brakes while backing up - predominately on rainy days, after I washed the car, etc. - anytime a light rust film formed on the rear rotors. After I had the dealer replaces the rear carrier bushings called for in the tech bulletin, the noise went away.
Regards:
Oldengineer
Old Jan 12, 2009 | 11:07 PM
jvegas's Avatar
well i guess I will look for that TSB. Thanks!
Old Jan 13, 2009 | 07:29 AM
Interesting - see Oldengineer, it's a good thing you still hang around!
My car did it sporadically, but when I cleaned everything, it went away.
Old Jan 13, 2009 | 08:01 AM
jvegas's Avatar
i can't find the TSB, any one have it?
Old Jan 13, 2009 | 09:31 PM
Vegas:
Its JTB00048(Version2) for the 2005-2008 model years.
Regards:
Oldengineer
99xk8guy
May 28, 2024 09:36 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
SteveSheldon
UK & Eire
Sep 8, 2015 11:22 AM
MrMellor
Sep 7, 2015 10:22 AM
Balboa
Sep 5, 2015 11:32 PM
