wheel bearing help!
Old Jan 24, 2009 | 09:53 AM
Luemasta32's Avatar
Default RE: wheel bearing help!
Well I've just been being lazy about it, but I guess I'll get my speed sensors checked out. Real_Tech got any idea's why my cars instrument cluster switched languages on me.
Old Jan 24, 2009 | 06:58 PM
Real_Tech's Avatar
I've never seen an IPK switch languages by itself. There is a procedure to switch the language manually with some button presses on the headlamp switch trip computer buttons. I looked for it Friday and asked all the other techs if they could remember the procedure(not very common request) and we couldn't find it anywhere. Maybe one of the other techs here can remember the procedure, otherwise the search will continue on Monday. If all else fails it can be reset with the IDS at a dealer.
Old Jan 24, 2009 | 07:58 PM
Luemasta32's Avatar
Not the biggest issue, but like you said not very common hahah. Thanks for the advice and i'll see what I can get figured out.
Mike
Old Jan 24, 2009 | 08:23 PM
Luemasta32's Avatar
Well mystery solved. All I needed was a direction to go in and after looking around a bit I figured out how to set it. Pretty simple goes as follows
1) Hold in m/km button by the headlight switch and turn the key to position II. A language selection should appear.
2) Press m/km button to cycle through languages.
3) Press A/B button once desired language is on the screen.
PMKimpton
Aug 3, 2019 08:22 PM
iownme
Sep 17, 2015 07:30 PM
Richard_gib
Sep 12, 2015 07:08 PM
sawduster
Sep 11, 2015 10:02 PM
Harry Dredge
Sep 3, 2015 03:04 AM
