Wheel specs?
Old Sep 7, 2009 | 11:17 PM
Wankel's Avatar
Default Wheel specs?
Can anyone tell me what the specs are on this wheel?
Looking for Width and Offset. I believe its a 16" I would have to look again at it, but im more concerned with width and primarily offset.
I could probably take it off, but I dont have the tools at my place.
Old Sep 8, 2009 | 04:45 PM
Thermo's Avatar
Veteran: Navy
Wankel, the stock 17" rims are 17x7.5" rims with a +40mm offset. They use a 108mmx5 bolt pattern. not sure what other information that you may be after. The backspacing is 5.5" as I recall.
Old Sep 8, 2009 | 06:13 PM
Wankel's Avatar
Yes, but as I thought, I have the 16" wheels. Do you happen to know the width and offset of the 16" wheels pictured above?
Old Sep 8, 2009 | 07:06 PM
lymeboy's Avatar
You could probably remove a wheel and look at the back as quickly as firing up your computer. If you are trying to determine compatibility of a different wheel you could go to Tirerack.com or other vendor and look up your new wheel to check compatibility.
Old Sep 8, 2009 | 07:07 PM
Thermo's Avatar
Veteran: Navy
Wankel, the 16" rims are 16x7" rims, using the 108x5 bolt pattern and the +40MM offset.
Old Sep 8, 2009 | 07:09 PM
MarkC's Avatar
The wheels in the car pictured above are 16" x 6.5" wide. Offset is 52.5 mm. I just read this off of a spare wheel in my attic.
Mark
Old Sep 8, 2009 | 07:20 PM
Wankel's Avatar
Very cool, thanks mark!
aholbro1
Dec 29, 2024 06:46 PM
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
lickahotskillet
Sep 11, 2015 07:54 PM
iownme
Sep 11, 2015 02:57 AM
