Where is the clutch master cylinder?
Old Aug 30, 2011 | 08:30 PM
cujet's Avatar
Default Where is the clutch master cylinder?
My 2003 2.5L 5 speed, 106K miles, has the dreaded clutch pedal problem, where the pedal sticks down. I pull it back up manually from time to time. Today, I noticed a significant brake fluid leak where I park, and suspect it's from the clutch master cylinder.
So, I jacked up the car and went in search of the clutch master cylinder. I don't see it. I can easily see the bottom of the brake master cylinder and it's not leaking.
Any thoughts?
Thanks!!!
Old Aug 31, 2011 | 11:07 AM
Luka's Avatar
Master cylinder is under clutch pedal. Perhaps you mean slave cylinder?
Old Aug 31, 2011 | 02:41 PM
cujet's Avatar
Ah, thanks.
My oil dripping was not brake fluid after all. It was transfer case lube.
Old Sep 25, 2012 | 10:42 AM
mobilextc's Avatar
It took me days to located the clutch slave cylinder. I wish I found this diagram before wasting so much time. Excellent diagram.
PhilXJ6
Jan 3, 2016 08:55 PM
Delta66
Oct 4, 2015 05:40 PM
baskervillema
Oct 1, 2015 01:59 AM
dan102877
Sep 29, 2015 06:47 PM
