where to get IMT gaskets?
Old Feb 15, 2012 | 07:59 PM
iownme's Avatar
Default where to get IMT gaskets?
hi... i couldn't find any on ebay...i searched for IMT gasket...thats correct right?
Old Feb 16, 2012 | 04:42 AM
joycesjag's Avatar
Look here, top of post #1. Dealer or Motor Cars, part #s and pricing:
https://www.jaguarforums.com/forum/s...ics-faq-32135/
Old Feb 16, 2012 | 09:51 AM
iownme's Avatar
thanks, just ordered them. I'll probably pull the intake to install them
Old Feb 16, 2012 | 11:33 AM
AML's Avatar
AML
You don't have to pull off the intake manifold to replace them. It just takes some smooth careful manipulation to get the new o-ring on with the bottom set.
Old Feb 16, 2012 | 01:10 PM
Mimmo's Avatar
Default O-rings
i replaced mine last year. Its not difficult to work the o-ring over the valve just in cae you're considering. Also replaced the power booster line at the same time.
Old Feb 18, 2012 | 07:21 AM
joycesjag's Avatar
If access to the lower IMT valve is tight, you do not have to remove the valve fully. Just slide it out far enough to see the old O-ring, remove the electric connection and slip old O-ring off the back, to install roll new O-ring on.
Old Feb 19, 2012 | 07:01 AM
iownme's Avatar
thanks for the time saving tips...i read another thread here which stated there were 2 ways to instal them....either removing the intake or removing the engine brace bar.
I still may remove the intake as now may be a good time to replace the lower intake gaskets...i repla ced the upper gaskets a few months ago...i was in a rush and didn't have the extra hour to do the lowers.
IMT gaskets will be here in a couple of days so i'll update when i instal them.
thanks again to all
Old Feb 19, 2012 | 08:36 AM
RealmCenter's Avatar
This is a good opportunity to do a full tune up (depending on mileage) there is no other way to do the rear plugs other than pulling the intake. I take the opportunity when I do IMTs to do a full tune up with plugs, PCV valve, airfilter, fuel filter, injection system clean, etc... If it's not due for those things than slipping the o-rings off the back of the valve is much easier and saves a lot of time.
Old Feb 20, 2012 | 04:40 AM
iownme's Avatar
realmcenter...thanks for the info....i replaced the plugs last month when i had the upper intake off to do the upper gaskets.
When i bought the car there was some kind of black silicone smeared around the IMT valves, so i know the gaskets are probably shot.
on rare occasions the rpms will drop a tad when coming to a stop then go back to normal....it feels like a vacuum issue...barely noticeable...but i'd still like to address it.
When the gaskets arrive i'll try installing with the intake still on
Old Mar 12, 2012 | 05:19 PM
spyderman's Avatar
Default I replaced my IMT O-rings
I replaced IMT O-rings in about 15 Minutes. The only issue I had was the Bottom sensor is a very tight fit and you have to be patient but it will come out.
Jaguar O-RING VACUUM SEAL FOR UPPER INTAKE MANIFOLD CONTROL VALVES - C2S40669005
This is where I got my O-rings. The Old ones were Yellow , dried out and flattened. The new ones were Green and they fit very snug with a little lithium grease to make sure they slid on nicely and the sensor slid in smoothly.
So far this has fixed my car going into limp mode at 2900rpms
04 Xtype 52000 miles
Old Aug 7, 2014 | 04:38 PM
00franky00's Avatar
How to replace the o-rings.
X308XJR
May 20, 2019 06:50 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
pnwrs2000
Sep 30, 2015 01:56 PM
hoodun
Sep 28, 2015 08:32 PM
