WHY are spark plugs ejecting?
Old Sep 22, 2018 | 01:09 PM
iownme's Avatar
Default WHY are spark plugs ejecting?
so now a 2nd spark plug has ejected itself from bank 1 taking the threads with it and a meltdown of the coil.
can anyone explain WHY this is happening.
plugs were replaced almost a year ago, maybe less, with the correct champion platinums
Old Sep 22, 2018 | 02:11 PM
Dell Gailey's Avatar
I know the Ford Triton engines are spitting out plugs like watermelon seeds but, they finally sent a TSB out after Ford was denying it forever. The root cause seems to be aluminium heads and very short plug threads. The insert repair seems temporary and many have resorted to helicoil repair.
https://m.carsdirect.com/car-repair/...roblems-solved
https://www.cartalk.com/content/my-w...ree-months-ago
https://www.quora.com/What-are-the-p...-out-of-a-head
Old Sep 22, 2018 | 02:53 PM
Thermo's Avatar
Veteran: Navy
iownme, I know the Triton engine issue all too well (fixed that issue on my Expedition). In short, what you are seeing can be caused by one of two things: 1) spark plugs not tightened/torqued sufficiently, and 2) spark plugs tightened/torqued too much. It is a fine balance. The Ford issue was that they only had 3 threads in the head to hold the spark plug in place and after doing a plug change, some of this metal stuck to the plug and when the new plug was put in, it overly stressed the aluminum and after about 5,000 miles, would eject the plug. In my case, I had the same plug blow out twice (I could reinstall the plug after it blew out the first time). I ended up buying the special Timesert kit and I drilled out all 8 plug wells and put the new sleeve in. Much better than a helicoil as there is no means for the gases to wind their way up around the gap in the helicoil and the sleeve put in a minimum of 6 threads everywhere, vice being still stuck with the 3 threads in the head. But, this also involved me pulling the heads off of the truck to ensure I didn't get any metal shavings in the engine. But, it did give me a reason to port/polish the heads. He he he he he he.
Old Sep 22, 2018 | 03:05 PM
iownme's Avatar
gents...this has just been such a frustrating month jagwise.
you may remember my post a few months back about using inserts (which is what i used back then) luckily i have a spare insert and new plug in the garage and i have just finished tapping the hole to take the insert.
i also had the ford problem on a 97 f150...
very long story short i ended up buying a brand new engine from ford.
im glad to have tools/ability and a forum to complain to.
at least im not paying out thousands of dollars with these diy repairs
Old Sep 22, 2018 | 04:34 PM
Work on car.....have a beer break.....work on car....have a beer break.....work on what was it again? Yeah car....have a beer break.....yeah it'll wait until tomorrow......
Old Sep 22, 2018 | 04:53 PM
iownme's Avatar
i dont drink so that wont work...i quit smoking this year so that adds to the stress level...i seriously almost looked fior a smoke but i persevered!
good news is the new plug and insert is in...its all back together now.
fired her up and all seems well, no codes, no check engine light ;@)
lucky my neighbor was around with a spare tube of red grease
found a new set of upper intake gaskets and imt O rings in the garage i must have ordered years ago so i threw all that on too
Old Sep 22, 2018 | 04:57 PM
iownme's Avatar
remains of coil left attached to spark plug
Old Sep 22, 2018 | 07:48 PM
So, I'll have one for you, bud. :-) :-) :-)
Old Sep 22, 2018 | 07:52 PM
iownme's Avatar
have 3...or more ;@)
maybe on this rare occasion i will have a celebratory one!
Old Sep 23, 2018 | 08:21 AM
Thermo's Avatar
Veteran: Navy
iownme, if you ever get another Ford and you need that kit, let me know. My kit is better traveled than most people. I have sent that kit all over the US. The guys in my truck club would have the issue and I would send the kit to them. I just asked that they cover the cost of shipping and bought their own inserts. I got the same run around from Ford. they tried to tell me that my engine was shot at 100K miles and that they could fix the problem after I spent almost $6000 on a new engine. I knew better. I told them where they could put that new engine and I did the whole fix plus upgraded the engine for under $1000 and had something that is guaranteed not to fail again (which Ford would not say they could do).
I hear your problems. take it slow and steady and see what you find. I would say at this point it may be worth your time to pull the remaining 4 plugs and see what you have. Better to find the issue now than when you are on some dark, lonely country road and "pop goes the weasel".
Old Sep 24, 2018 | 11:09 AM
iownme's Avatar
thankyou thermo, thats very kind!.
with my 4.6...i sent it out to be rebuilt.
took forever...got it back in the truck...didnt work....sent it back again....took forever... got it back in truck again.
didnt work....took it out....went to ford....bought new engine.
i wasnt as experienced back then....now i would have likely fixed it myself.
that story continues in the same vein....lol... much like this current x type....it must be me!
lol
as for doing the rest now....im more of a " if it aint broke" kinda guy, i have AAA, a cellphone and a credit card...haha
i can do this job in a parking lot if i had too now, especially as im now gonna add my air tank to the trunk full of tools and extra plugs coils and inserts!
arath25
Sep 1, 2014 07:23 AM
dkovac
Aug 26, 2012 12:06 PM
Dave Jarvis
Jul 4, 2011 07:41 AM
Taktikz
Aug 12, 2008 11:31 AM
