X type 08 Apline Amp
Old Feb 10, 2019 | 02:03 AM
plugly's Avatar
Default X type 08 Apline Amp
Hi,
Ive just brought another X type to replace my older high mileage 2.2 and its got the alpine audio system in it, but the audio is very lower and has hissing / fizzing sound when anything comes though the speakers.
this is via the radio, cd or satnav, has anyone seen this fault.
my thoughts are component fault in the amp causing the noise in the audio channels.
any ideas would be great.
Steve
Old Feb 10, 2019 | 06:11 AM
x_type_lpg's Avatar
if you have the alpine amp you will have DSP on the display when tuning radio stations. all the audio is fed via the optical cables to the amp in the boot that then converts to electrical signals that drive the speakers, there is no link between the radio unit and the speakers. chec the optical connections are all firmly in place.
Old Feb 10, 2019 | 08:46 AM
plugly's Avatar
Fixed the problem, there was corrosion on the bottom of the circuit board that was causing it arc in two spots, one component had lost its legs and solder pad from corrosion.
Repaired the unit. all is working well.
JimC64
Sep 22, 2025 02:52 PM
EzSTR
May 11, 2018 05:34 PM
jimlombardi
Oct 21, 2013 03:44 PM
