x type 2001 2.5 litre,the engine management light
Old Apr 5, 2010 | 08:31 PM
trevor112468's Avatar
Smile x type 2001 2.5 litre,the engine management light
Ihave an x type 2001 2.5 litre,the engine management light,abs light have come on & also the cruise control has stopped working, any ideas ?
Old Apr 5, 2010 | 09:33 PM
Colt's Avatar
Banned
One for sure thing..It has nothing to do with the Oil type you're using..
Old Apr 7, 2010 | 02:46 AM
Trevor I moved your post to a new thread because it does not appear to be related to the original discussion about oil types and weights.
Can't help much with your X-Type problem but there are some great guys in here that should be able to offer you some advice.
One thing I am fairly sure of however is that when your engine management light comes on then by default the Cruise Control will de disabled.
Hope you are able to get it sorted,
All the best,
Old Apr 7, 2010 | 03:39 AM
Green Machine's Avatar
Smile
Trevor,
We've had a rash of this type problem this past winter. The usual cause has been a vacuum leak around the IMT valves on the intake manifolds, also some have found leaks in the power brake booster line from the manifold or the PCV line that runs under the engine cover. I don't know how things work in your country, but here in the US there are several auto parts stores that will read the codes stored on your computer for free. With these codes you will at least have an idea where to start looking for the source of your problem.
stanjag
Dec 29, 2024 08:26 PM
GuernseyJag
Nov 8, 2017 10:40 AM
sorken88
Aug 28, 2015 04:09 AM
daro31
Aug 27, 2015 09:26 AM
dpappyp
Aug 27, 2015 06:31 AM
