X-type AC
Old Jan 15, 2014 | 10:28 AM
lawechan's Avatar
Default X-type AC
Hi, I just bought a pre-loved x-type a few weeks ago and i have noticed that the air coming out from the AC on the passenger side is colder than the driver side, also the air seems to not cold enough even if the temp. setting is at 22.5 deg C.
Appreciate any feedback as to the possible reason or probem.
Old Jan 15, 2014 | 10:38 AM
Aonsaithya's Avatar
I had the same issue earlier, it was low on coolant fluid stuff. After that was remedied, it was sufficiently cold.
Old Jan 15, 2014 | 12:13 PM
Thermo's Avatar
Veteran: Navy
lawechan, odds are, you freon charge is a little low and you simply need some more freon added to the system. A set of freon gauges will tell you if that is the case or not. Blindly adding freon to the system can cause more problems than it fixes. So, do not just add freon without the initial gauge check.
It is also possible that the blend door has slipped and that is causing what you are seeing. This is where if your freon pressures are where they should be, then that will help confirm that your problem is the blend door.
Old Jan 16, 2014 | 01:29 AM
lawechan's Avatar
Appreciate your reply Aonsaithya and Thermo, i have brought the car to the shop for check-up. I will post it the finding and recommendation of the technician.
Old Jan 17, 2014 | 03:07 AM
lawechan's Avatar
I had my x-type checked in a shop specializing in European cars,
initial recommendation is to change the following;
a) Evaporator
b) Expansion valve
c) drier
d) Oring
e) re-charge freon 134A and 141B
f) change compressor oil
total estimate : USd 830.00 including labor
appreciate your feedback if the technician made the correct recommendation and also if the cost is reasonable.
thanks !
Paora
Feb 4, 2021 12:36 AM
Msteiner
May 16, 2016 12:19 AM
jospolice
Oct 2, 2015 07:16 PM
millertic
Sep 30, 2015 08:11 PM
