X-Type Airbag Suspension Project Thread
Old Mar 22, 2012 | 10:22 PM
  #81
Alan Sifuentes's Avatar
Default Nice set up have a course questions.
I have a 2005 x type and I want to put the same set up. Can u send me the parts list u ordered. And do I have to use parts from my old suspension to install the bags. Also if u have can u send some of the install pics.
Thanks.
Old Mar 22, 2012 | 10:30 PM
  #82
exexpat's Avatar
Thanks.
I don't really have additional pics, the key is the rear, you just need to use the upper brackets and not the lower ones. You'll need to trim the upper spring cups to avoid the metal cutting into the bags. Rear sway bar (if you want to keep it) needs to be mounted upside down - that limits you max height to about an inch above factory. Fronts are drop in, but make sure struts are tight.
As for parts list, just call the guys at airbagit.com. I bought the Smartride system to have digital control, but those parts have improved since my purchase 2+ years ago. I also upgraded the air engine to better valves. It is a little of a DIY project, but not too difficult if you have a mechanical and/or car stereo installation background.
Old Mar 22, 2012 | 11:15 PM
  #83
Tht sounds good I have about 7 years experience in custom car audio and plenty more working on cars. So you didn't have to weld or buy lowering shocks.
Old Mar 23, 2012 | 07:01 AM
  #84
exexpat's Avatar
Cool. We are like brothers then I used to build IASCA competition cars back in the late 1990s. One more thing about the rear.... You need to cut off the bump stop metal mounts in the rear. They are on the top side of the springs - get them as close to the upper perch as you can. You can then just drill into the lower perches and bolt the bag directly to that. The upper one is where I routed the airline and I only drilled for the line and the mount up there. The upper mounting bracket will give you enough clearance to clear the bump stop metal and you'll want to pull out the "ears" a little of the perch (round them out to where the metal is a 45 degree angle with pliers), as they will otherwise eventually slice into the airbag upper bellow.
Good luck
Old Mar 29, 2012 | 09:01 PM
  #85
I been reading on the Internet and a lot of ppl put bad reviews on airbagit and I'm wondering how your kits is working for you and if u have had to replace anything. Or has it just been maintenance.
Old Mar 29, 2012 | 11:25 PM
  #86
exexpat's Avatar
Nothing has gone wrong except the LCD screen on my first Autoloc controller lost 2 digits. Airbagit warranteed that part though.
FrickenJag
Jun 16, 2025 02:15 PM
Jpav27
Jul 31, 2022 06:43 AM
Rivguy
Dec 4, 2020 07:55 AM
GordoCatCar
Jan 2, 2017 01:10 PM
Whitnessmouse
Sep 4, 2015 11:09 AM
