X TYPE Antifreeze Leak
Old Mar 8, 2010 | 07:44 PM
pnyklr's Avatar
Default X TYPE Antifreeze Leak
Did some home work and searches to find its could be a water pump gasket or possibly the T at the overflow tank
Problem being is if I heard correctly the mechanic didnt have the pressure tester for my car since they normally go on the radiator cap not the over flow bottle
I havent driven the car at all since this problem its sitting at the shop
but the window regulator and cabin filter are fixed
what can I do to trace the leak it only happens when I'm driving
if the car sits it doesnt drain out at all
Old Mar 8, 2010 | 07:45 PM
pnyklr's Avatar
also the car isnt overheating at all and I cant find a wet spot on the hoses or anything
Old Mar 9, 2010 | 06:53 PM
Thermo's Avatar
Veteran: Navy
pny, sounds like you have a possible problem in 2 areas. I would tell you to pick up the car from the repair shop, make sure it is topped off with some water and then with the car idling, use a flash light and follow the trail of antifreeze. From there, you should be able to trace it back to the source of the leak. Based on what you are describing, it sounds like the connection at the bottom of the overflow bottle has busted on you.
stanjag
Dec 29, 2024 08:26 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
Russ Graber
Feb 23, 2019 11:59 AM
Aranon
Sep 3, 2015 07:56 PM
Spikepaga
Aug 30, 2015 12:59 PM
