x-type common issues?
Old Mar 16, 2014 | 11:48 AM
stevepaa's Avatar
Default x-type common issues?
So i searched for problems, issues and nothing really came up.
I am considering a 2007 wagon with 131000 miles. What issues are common with these cars? thanks
Old Mar 16, 2014 | 02:20 PM
Pinecone's Avatar
The wagon-specific issues might be:
The rear wiper motor gets seized up due to water leakage and corrosion.
The rear glass switch goes bad.
The glass latch itself goes out of alignment.
So check to make sure both of these things work well.
The X-type has issues with air leaks around the intake manifold, oil pan gasket leaks, transfer case failure, prop shaft bearing failure, and all sorts of electrical failures of the gadgets inside the cabin.
I don't know why you couldn't find any reference to these things - this forum has them covered numerous times.
Old Mar 16, 2014 | 02:51 PM
Tony_H's Avatar
Look carefully at the lower A pillars. That's where X Types fatally rust.
Old Mar 16, 2014 | 05:41 PM
04xtype04's Avatar
With that many miles you want to make sure the transmission/transfer case are in good working condition and have been maintained. Unless you are getting the car crazy cheap, those are expensive repairs. Little plastic bits get old and break too. Headlight adjuster screws break off on most x-types, but can be repaired with a part. Transfer case seems to be the major thing, I think they run out of oil and people drive them too hard. Other than that, I've seen people on here with 175,000+ miles. They can be a bit expensive to maintain and repair because they require good parts and usually more labor than average cars, but if you can do some of the maintenance yourself, it's a fun car to work on and you get a lot of help from people here on the forum.
Old May 18, 2014 | 10:36 PM
jagxtype76's Avatar
Hey Tony what do you mean A pillars and fatally rust?
Maybe I'm lucky cause I'm in WA state and cars don't seem to rust here I just bought this car and its a 2004 now its 2014 I didn't see a spot of rust on this car
Old May 19, 2014 | 03:20 AM
henry k's Avatar
I recall seeing some really horrific photos of such rust on early versions.
It was also stated that the fault in draining water had been fixed on later models so I would not be concerned about a pillar rust with
Old May 19, 2014 | 03:33 AM
henry k's Avatar
Not sure if Jaguar locking ( security) wheel nuts are fitted in the US.
If so ask for them to be romoved and refitted ( to the correct torque )
This ensures the removal key ( socket ) is presentand all works OK
Ensure you have two fully working ignition keys.
Replacements can be very expensive and difficult to source.
If the keys supplied have been cloned then you cannot create further keys.
99xk8guy
May 28, 2024 09:36 PM
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Whitnessmouse
Sep 4, 2015 11:09 AM
Jjscruggs1
Sep 3, 2015 07:46 PM
