X type demister
Old Nov 9, 2013 | 06:20 AM
cbodman's Avatar
Default X type demister
The demister on my Xtype is not working. My local garage can't find the solution but say there is a leak on the air conditioning. I have booked a diagnosis at the main dealer but that is 60 pounds an hour. Has anyone had this problem. CB
Old Nov 9, 2013 | 09:46 AM
Robert Scott Neilly's Avatar
I can think of two possible causes; if the (two) fuses that feed the electric heating function of the front windscreen are blown (they are located in the fuse grouping in the engine compartment, front right side) that could be your problem, or it may be that the 'fresh air/recirculated air' door in the heater assembly has failed in the 'recirculating' position, and you have too much humid air blowing on the windscreen. There is a thread on how to fix this rather common problem with the Xs
Old Nov 9, 2013 | 03:30 PM
iownme's Avatar
https://www.jaguarforums.com/forum/a...2&d=1262224022
Link on fixing the blend door
way2far
Aug 31, 2022 09:26 AM
ZJag
26
Sep 5, 2016 03:33 PM
KarimPA
Sep 12, 2015 08:15 AM
raffoulig
Sep 8, 2015 01:56 AM
KarimPA
Sep 3, 2015 07:32 PM
