X type engine failure
Old Jan 31, 2011 | 05:09 PM
test point's Avatar
No CEL?
I am out of my knowledge area on X Types but on the XJ/XK I would check the power relays to the ECM and the connectors on the throttle body.
Old Jan 31, 2011 | 05:14 PM
I don't have a solution to your problem, but I have removed your email address, it is not wise to post it on an open forum.
Old Jan 31, 2011 | 07:53 PM
Thermo's Avatar
Veteran: Navy
J Solters, normally with the X-Types, a problem like this is associated with the fuel pump. A check that you can do is to get the car to fail. Then, cycle the key to the OFF position and then back to the RUN position (do not attempt to start the car). You want to be near the rear passenger door with your head semi under the car. What you are listening for is the sound of a running pump. This would be the fuel pump. No noise, fuel pump is not working. The more accurate way is to use a fuel pressure gauge. There is a schrader valve inside the engine bay that you would need to connect up to. Then you are looking for the fuel pressure to rise to about 50 psi with the key in the RUN position and the engine not running. But, short of running around with a gauge in your car just because, the easier check is the hearing method.
From there, we can narrow things down for you.
stanjag
Dec 29, 2024 08:26 PM
fast40driver
Apr 19, 2024 07:24 AM
trucknetjack
Sep 13, 2015 09:17 AM
dpappyp
Aug 27, 2015 06:31 AM
NinoGrimace
Aug 26, 2015 05:15 AM
