x Type jag running on 5 cylinders ?
Old Feb 17, 2009 | 04:05 PM
Thermo's Avatar
Veteran: Navy
Tambo, while I can't speak for Jags specifically, but on my Ford, the COP (coil on plug) for each plug can develop a crack in the top of them, allowing moisture into them. Once this happens, it can cause the COP to short out internally, not allowing the cylinder to fire. I would check the top of all your COPs and see if any are cracked. In a lot of cases, this is the easy way to tell which cylinder is not firing on a Ford. This same logic should still apply as Ford owned Jag and shared a lot of technology between the two.
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
Will P
Aug 27, 2015 06:52 PM
dpappyp
Aug 27, 2015 06:31 AM
