X-Type Parking Aid Module Help Please!
Old May 7, 2013 | 06:15 AM
OscarOtter's Avatar
Default X-Type Parking Aid Module Help Please!
Unfortunately my boot flooded and killed my module! From what I hear this is a common problem on the X-Type, I still don't know where the water came in, all carpets trim etc. were dry. I have removed the drain plug to prevent a re-occurrence, and am now searching for an affordable replacement part.
I have been told that Ford Mondeo and Land Rover Freelander 2 units should work, the shape and manufacturer (VALEO) are the same. However the numbers are not.... Mine is 4x43 - 15K866 - AD. Can anyone please tell me what these numbers mean? 15K866 seems to be common to all.
The Plugs on the unit from left to right are 16 pins, 12 pins and 12 pins. Which is supposed to be the live feed? Which fuse services it because the glass hatch stopped working at the same time!
Any advice would be most welcome.
Old May 7, 2013 | 07:05 PM
Thermo's Avatar
Veteran: Navy
Oscar, the "4X43" is simply stating that it is from an O4 Jaguar X-Type if I remember the coding right. So, as long as the middle part is the same, you should be golden. THe 2 letters on the end as I recall were revision numbers for the programming in the computer. But, for the most part, nothing major was upgraded with the parking aide module unless you got the front and rear system vice just the rear system.
Steviedee1st
Nov 28, 2023 06:32 PM
abonano
25
Sep 25, 2015 10:43 AM
simo5555
Sep 9, 2015 06:22 AM
tberg
Sep 7, 2015 07:32 AM
laserguy
Sep 3, 2015 02:02 PM
